Plumbing & Plumbers Forum - Swap actuator head - Wavin
  • 1 Post By mmc501
Discuss Swap actuator head - Wavin at UK Plumbers Forums; In our UFH I have noticed that 2 actuators are in the wrong position. When the stat for a room is calling for heat 2 actuators open but 1 of ...
    Nov 2016
    Default Swap actuator head - Wavin
    In our UFH I have noticed that 2 actuators are in the wrong position. When the stat for a room is calling for heat 2 actuators open but 1 of them is to the wrong pipe so 2 need swapped over.
    Would they simply screw off or clip off?
    Is this something I could do myself or would I need to get plumber back.
    It is a Wavin UFH Sytem
    Pic below.
    ** UKPF Sponsor **
    Jul 2016
    71
    Default Re: Swap actuator head - Wavin
    Hi there,
    I don't know how to remove these ones I'm afraid. The other type Wavin does is a "clip on" type and you have to press two tabs to remove it but I can't see it on these ones.
    Might be worth to check it with Wavin technical team.
    Actuators are only pushing the pin valves up and down so once you know how to remove them you can over on the manifold on your own.
    If you need to unplug them from wiring centre and you you don't feel confident perhaps you could get an electrician to do it. Usually there's 2 wires (L + N).
    Hope that helps.
    Regards
    Nov 2016
    Thanks for the info re clipping - I turned one of them round and there was a clip at the back - pressed it firmly and it popped off handy enough. Easy enough - cheers.
    Uheat – Wojtek likes this.
  1. Old wavin fittings
    By al2016 in forum Plumbing Forum
    Last Post: 04-08-2016, 07:21 AM
  2. Wavin ufh manifold problem
    By steve1 in forum Central Heating Forum
    Last Post: 12-10-2014, 04:55 PM
  3. Replies: 2
    Last Post: 08-05-2011, 09:03 PM
