Results 1 to 4 of 4
Plumbing & Plumbers Forum - UFH or CH
UFH or CH
Discuss UFH or CH at UK Plumbers Forums; Hi there I hope you guys can help me. I have a set-up that I can't understand and Scottish Gas "engineers" don't seem to either.. The Scottish Gas engineers claim ...
    Nov 2016
    Default UFH or CH
    The Scottish Gas engineers claim I have a full underfloor heating system but I only have electric underfloor heating in the bathrooms (each with a thermo-stat) so they point blank walked out as they don't cover UFH.
    For the CH I have a 2 zone system
    Zone 1 - thermostat in the living room/kitchen area - 3 rads in there, 1 radiator in the hall, and 1 towel rail in bathroom.
    Zone 2 - Thermostat in Master bedroom - 1 radiator in there, 1 towel rail in en-suite, 1 in spare bedroom.
    I also have a another radiator in the hallway which is always on and doesn't have a TRV I believe that's normal for circulation purposes.
    Here's where I understand the confussion for the Scottish Gas engineers comes from, I believe the installers of the system installed acutuators that are usually used for UFH to control the CH thermostats, am I correct??
    So the reason why the actuators are off from the valve are if they're on I can't get heating at all, I have no control from the room thermostats.
    On the lower valve the pin is stuck and the above the pin moves freely.
    The only way I can turn heating on or off is by using the dial on the boiler.
    For UFH
    Bathroom - Electric underfloor heating - thermostat outside (Elements eStat 762)
    Ensuite - Electric underfloor heating - thermostat outside
    Nov 2016
    Default Re: UFH or CH
    Can anybody just clarify if they think this is underfloor heating set up or for central heating.
    ** UKPF Sponsor **
    Jul 2016
    71
    Good morning Bushman,
    manifolds are also being used for radiators, not just the UFH.
    If you are sure that you haven't got an water based UFH then I don't understand why gas engineers are telling you that you have.
    Hope that helps.
    Nov 2016
    Quote Originally Posted by Uheat – Wojtek View Post
    Hope that helps.
    Ok say the manifold are also being used for under floor heating would it be common to have a thermostat in each bathrooms for underfloor heating and 2 central heating room thermostats. I don't understand how a call for heat would be achieved with only 2 actuators?
