Results 1 to 12 of 15
Plumbing & Plumbers Forum - ufh under kitchen unit
Like Tree10Likes
Discuss ufh under kitchen unit at UK Plumbers Forums; search the web on this subject, getting both yes and no answers. Hoping I can get an definite answers on here....
    Oct 2009
    111
    Default ufh under kitchen unit
    Chalked's Avatar
    3,985
    Default Re: ufh under kitchen unit
    Where you are short of heat output, you can go under the units. But it's best not to, especially where you want to store food.
    Uheat – Wojtek likes this.
    Jun 2013
    1,818
    What the situation?
    Are you having it installed or is it already installed?
    Are you remodelling the kitchen?
    Oct 2016
    Leeds
    176
    If you're remodelling the kitchen then simply adhere some kingspan or similar product underneath the cabinets & fit some vents to the plinths to allow the heat to circulate into the room, If you're installing the UFH then why waste time, energy & money on extra meters of pipework etc. that's really unnecessary, & will give no benefit to the end user at all just heating a dead space.
    Uheat – Wojtek and Masood like this.
    ** UKPF Sponsor **
    Jul 2016
    77
    Hi there,
    when we design the system we never go for UFH under the kitchen units (as long as we know exactly where kitchen units will be).
    In some cases when customers haven't got a final design of the kitchen they cover the whole area with pipework and then they use thin layer of insulation board underneath the cabinets.
    Hope that helps.
    Jun 2012
    London/Kent
    4,013
    Quote Originally Posted by Uheat – Wojtek View Post
    Hi there,
    Hope that helps.
    Can you please explain why? (apart from the cost)
    I thought that these system were more of less self regulating i.e. as the air temperature increases the heat flow from the thermal mass of the floor decreases.
    If there is no heating of the thermal mass under sections of the floor isn't heat drawn away from those areas that are, reducing warm up time & possible effecting overall heat outputs?
    Thanks Chris
    BurstPipe likes this.
    ** UKPF Sponsor **
    Jul 2016
    77
    Hi Chris,
    Running the pipes under the kitchen units doesn't cause any problems as long as there's no food being stored in the kitchen units.
    This is the main reason why most of companies don't recommend to install the UFH underneath the units.
    I agree with the fact that colder screed will suck the heat from the warmer areas but's it's only for the initial heating up times.
    If there's plenty of units within the kitchen we normally narrow the pipe spacing to 150mm which reduce the response time to provide a bit more output.
    Regards
  8. The Following User Says Thank You to Uheat – Wojtek For This Useful Post:
    Jun 2012
    London/Kent
    4,013
    Many thanks for your input Uheat
    I wish I had U/F under my kitchen units the plates are bliming freezing this time of year.
    Jun 2012
    London/Kent
    4,013
    Just had a look at your Web site 32mm pipe haven't seen that before!!
    That might come in handy for some of the larger jobs, what sort of heat loads can it supply at say 70/50?
    ** UKPF Sponsor **
    Jul 2016
    77
    Morning Chris,
    32mm pipe is being used for general plumbing together with press or compression fittings.
    We've never supplied 32mm pipe for the UFH, even for commercial jobs we've done 20mm pipe @ 300mm / 200mm centres depends on the project requirements.
    I haven't even got any figures with outputs of 32mm pipe to give you honest answer.
    Have a good day.
    Jun 2012
    London/Kent
    4,013
    Morning Chris,
    Have a good day.
    I was thinking more about the distribution to manifolds etc rather than U/F circuits themselves, still handy to know.
    Thanks anyway Chris
  13. #12
  1. vaillant 438 heat onlt boiler + VR 65 Control Unit + 140 Time Unit
    By Richard at Home in forum Central Heating Forum
    Last Post: 22-10-2015, 11:36 PM
  2. Kitchen unit backboards
    By Keefy in forum Plumbing Forum
    Last Post: 27-05-2013, 04:16 PM
  3. kitchen sink waste disposal unit
    By gravytrain in forum Plumbing Forum
    Last Post: 31-10-2011, 11:27 PM
  4. powerflushing unit
    By sav in forum Plumbing Tools
    Last Post: 24-05-2010, 04:15 AM
  5. Replies: 3
    Last Post: 27-10-2009, 06:21 PM
