Results 1 to 12 of 16
Plumbing & Plumbers Forum - underfloor heating installation problem
Like Tree3Likes
Discuss underfloor heating installation problem at UK Plumbers Forums; guys , can you assist , have had underfloor heating installed and it is becoming a nightmare as different people are involved ie underfloor people , electrician and plumber. i ...
    Oct 2016
    Default underfloor heating installation problem
    i am far from happy with job and it is due for commissioning this week even though i have told both the plumber and ufh contractors things arent right.but they are are passing the buck between the contractors
    the ufh has been plumbed in (white tube on picture ) without any zone valve , when the electrician fired it up , all it did was heated up existing radiators and hot water(with existing timer to house swithced off).
    the words of the plumber are "there isnt a seperate zone valve , we piped it before youre original zone valve for that reason , so will have to wire in timer with the manifold"
    i am no plumber but can see the water takes the easiest route which is a straight passage to the existing mid position valve and into the existing radiators/hot water system
    please advise how it should be connected as even with my little knowledge things arent correct.
    Attached Thumbnails Attached Thumbnails underfloor heating installation problem-img_1546.jpg
    Oct 2013
    West Sussex
    3,387
    Default Re: underfloor heating installation problem
    You need to replace the 3 port (White headed Zone valve) with 3 no 2 Port Zone valves, the set up you currently have will always allow water to pass to the hot water cylinder when the UF heating manifold calls for heating.
    I'm easily confused so speak very very slowly
    Riley's Avatar
    Sarf Coast
    6,390
    Hmmmm surely they aren't telling you that's right
    manchester
    2,318
    Does that pipe go to a manifold (hopefully)
    1,996
    Who designed the system?
    Who's managed the different contractors?
    Who's commissioning it?
    The layout and components required and who does what should have been sorted out at the beginning, then the guilty party could now be held responsible.
    SimonG's Avatar
    16,038
    Need more pics of manifold etc. As Ch4 said above. 3 port out and 3 2 ports in.
    Riley likes this.
    Dec 2013
    The center of the universe
    4,179
    Quote Originally Posted by SimonG View Post
    Need more pics of manifold etc..
    Hopefully there is one , lol
    SimonG likes this.
    9,683
    dont think your plumber has a clue or qualified
    Oct 2016
    Quote Originally Posted by Riley View Post
    yes there saying its fine !!
    Oct 2016
    pipe goes to manifold
    Oct 2016
    Quote Originally Posted by snowhead View Post
    ufh engineers did the pipes in the floor , couldnt do plumbing as need as needed to be registered and my electrician who i have used a lot for the electrics
    the ufh technician provided nothing bar saying it was a simple water feed to and from the boiler and a plumber would find it easy to do
    Oct 2016
    manifold picture
    Attached Thumbnails Attached Thumbnails underfloor heating installation problem-img_1550-1-.jpg
  1. Underfloor heating problem
    By Davidgreer in forum Plumbing Forum
    Last Post: 09-11-2013, 01:11 PM
  2. Underfloor heating problem
    By FUGITIVE333 in forum Central Heating Forum
    Last Post: 25-03-2013, 08:28 AM
  3. underfloor heating problem
    By robbo in forum Central Heating Forum
    Last Post: 08-12-2012, 04:27 PM
  4. Wet underfloor heating problem HELP!
    By Kohini in forum Central Heating Forum
    Last Post: 29-01-2012, 08:53 PM
  5. Wet underfloor heating problem...!
    By merlecollins in forum Central Heating Forum
    Last Post: 17-01-2011, 03:13 PM
