Plumbing & Plumbers Forum - Underfloor heating challenge
Like Tree2Likes
  • 1 Post By ShaunCorbs
  • 1 Post By
Discuss Underfloor heating challenge at UK Plumbers Forums; Hi we are looking to install wet underfloor heating but only have 40mm of depth to play with as this is the existing screed depth which we plan to take ...
    Oct 2016
    Default Underfloor heating challenge
    Hi we are looking to install wet underfloor heating but only have 40mm of depth to play with as this is the existing screed depth which we plan to take up. The screed is currently supported by concrete floor. With such small depth to play with can anyone suggest an ideal solution for insulation/pipes/screed system.? Thanks
    9,673
    Default Re: Underfloor heating challenge
    I would have a word with u heat 01394384077 there on the web
    Uheat – Wojtek likes this.
    Jun 2013
    1,743
    You will probably find out that with that depth of screed, you will have to run the pipes closer to each other.
    So, if you run your pipes at 200mm centres, you will need to run them at 100mm centres.
    Double the pipework, but at least you will have a system that operates and performs.
    ** UKPF Sponsor **
    Jul 2016
    71
    Hi there,
    we could offer you our Ultraslim system which is only 18mm thick (same as 20p coin).
    Heavy boards are made from recycled gypsum, paper and water, mixed in an 80%- 20% ratio to produce homogeneous, dense sheet material that is cured, they are pre grooved for 12mm pipe which will be spaced at 150mm.
    Engineered wood (floating floor) and tiles can be laid directly on top.
    Parquet (if glued down to the surface) and carpet would require 6-9mm plywood or chipboard overboarding.
    It's a very quick installation method, boards can be fixed by low expansion fixing foam (which we also supply) which dries in 1hour.
    If you would require some more details or would like me to do a quote for you please feel free to contact me and I'll be happy to help.
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,685
    How are you going to put in insulation ?
  1. Noisy central heating since fitting underfloor heating
    By chippymike in forum Central Heating Forum
    Last Post: 15-03-2016, 09:37 PM
  2. Need Heating Engineer experienced in Wirsbo/Uphonor Underfloor Heating SG12 area
    By Fozzie Bear in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 23-10-2015, 08:15 PM
  3. South Yorkshire -heating engineer to fit heating system inc underfloor and rads
    By harrylime in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 01-07-2012, 12:17 PM
  4. Heating and hot water pipes condensation challenge
    By Robinwelch1000 in forum Central Heating Forum
    Last Post: 05-05-2012, 11:51 PM
