photoflash100
acdv
Discuss Zoneplus Z228 Valve in the Plumbing Zone area at PlumbersForums.net
Why is the pump after the valve ? I might be seeing wrong, I'm not allowed to see the pics !
( it says that sometimes on the website)
Get a pro in, good experienced heating engineer to look over it !
there's no problem. This was a new install. Just want to make sure they have installed the valve correctly
Me thinks shauncorbs is right.think the flows wrong as the filter is in the wrong place atm
Because the flow was originally the other way from pump to valve. Then I discovered they were pumping it up to the cold water tank feed!! So they came back and just turned the pump round so it would pump against the feed.
Reply to Zoneplus Z228 Valve in the Plumbing Zone area at PlumbersForums.net
