Discuss zone valves on s plan in the Plumbing Zone area at PlumbersForums.net
Hi quick question -
I notice honeywell do 2 types of 2 port zone valves
normally open and normally closed
Am i right in saying for a heating system the normally closed is the right one?
Also when would a normally open one be used?
Thanks!
Normally open = valve open if power is cut so makes it safer when using solid fuel
Normally you would use a normally closed valve but, if you were fitting one to a solid fuel system, normally you would fit a normally open valve as the heat source can not normally be shut off.
That is the normal way of doing it:p
Reply to zone valves on s plan in the Plumbing Zone area at PlumbersForums.net
