Discuss Zone valve or not? in the Plumbing Zone area at PlumbersForums.net
Irish
Evening all I've been asked to pice up a replacement boiler for a servowarm 50 so I'm thinking of a Wb 15ri my question is the cylinder is heated via immersion heater as are all the rest of the flats concrete floors means it'd be a nightmare to heat it via the boiler so as the boiler is only for the rads can I just use a programmable room stat without a zone valve or do I need the valve? Electrics aren't my strong point normally I get my mate to do the sparks side but he's on holiday at the moment, thanks
if you can run htg pipes why not pipes to cylinder
Pipes are already in the floor for existing rads they don't want any surface mounted pipe work
Reply to Zone valve or not? in the Plumbing Zone area at PlumbersForums.net
