J
jcjefferies
The boiler is almost three years old and I think I have given it a couple of small top ups when the pressure was getting close to 1. I just opened the front and the pressure gauge is reading zero so put in the key and added water very slowly but the gauge still reads zero. I have been round the radiators and there are no leaks and opening the bleed valves there seems plenty of water pressure possibly more than normal! There were drips for a while coming from the copper drain pipe which I think comes from the pressure relief valve which would confirm the high pressure. There are no warning or flashing lights so would this suggest anything other than a faulty gauge?
I hope not to need the central heating for several weeks but as its running at an unknown pressure would it be safe to use the central heating if it takes a while to get someone to look at the problem?
Chris
Chris
