Discuss wring glow worm betacom in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andyg0507
trying to wire in a siemens rdj10 programmable room thermostat to above boiler, wiring diagram only shows one wire going to stat on the 240v side???
L/N to receiver.. stat form boiler on choc block remove link and put one to Lx and one to L1
cheers for that, mi's showed diagram for 240v and 24v and didnt explain them very well, didnt want to go frying a pcb.
for 240 i think you have to run a live to lx then link across to l1 to run 240v bud
Reply to wring glow worm betacom in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
