Discuss Worchester Heat Slave 26/32 - low hot water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DustyM
I have a customer who's Worchester Heatslave 26/32 has started delivering hot water at a low pressure. Initially when the hot taps are turned on the water is delivered at a high pressure, but then gradually drops off to a trickle after about 15 seconds. I'm due to go around tomorrow and have initially got suspicions of the inline filter prior to the flow switch being perhaps blocked. From what I am being told, the boiler is heating water fine, and is also performing well on the heating side of things. I intend to check all inlet and outlets on the boiler for potential blockages; but not sure if there's anything else boiler wise.........................? Thanks:dunce2:
check incoming main pressure first someone may have been fiddling with stopcock.
There is also a flow restrictor after flow switch that could be blocked as well.
What's the cold water pressure like?
Check the filter and heat exchanger. If the heat exchanger is scaled up, take it off and drop it in a bucket of descaler for a couple of hours.
Thanks guys - the incoming cold pressure is fine; I'll be checking the filters and then move onto the heat exchanger.
Is it a sudden thing or more of a progressive decline in water pressure. If it's sudden the prob muck in a filter if it's progressive then I would be saying heat ex. Don't like soaking them tho, I just replace,
Reply to Worchester Heat Slave 26/32 - low hot water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
We have low hot water pressure in the entire house. Boiler is a Heatslave External 25/32, fuel in kerosene. The central heating is still working. Water initially heats up but soon flow ceases. The gauge pressure is correct. Do I need to release air or residue somewhere? Thank you.
Abram R
A
Hi everyone, we have low hot water pressure in the entire house. It doesn’t appear to be a problem with the boiler. A Heatslave 25/32 External. The central heating works. The hot water runs for a moment before shutting off. Should I be clearing residue or air somewhere? Thank you, Abram
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
J
Hi Can somebody tell me if a standard heat source pump installation uses a pressurized hot water tank? Or will the pressure for the hot water be the same as with my oil boiler and water storage tank (gravity-fed)?
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals. We've been in our house for over 3 years now, when we moved in the hot water pressure was pretty good (confirmed by a retired plumber family friend)...
