Discuss Worcester i28 problem in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Adam_BL
    Adam_BL New Member
    I have a Worcester i28 boiler and I am have problems with it. My downstairs radiators are getting slightly warm but not hot but the upstairs are still cold. My hot water works intermittently, sometimes nothing at all, sometimes it's coming hot for 5 seconds or so then cold for 10 seconds or so. Very occasionally the hot water come through constant.
    It sounds like the boiler is constantly firing up then cutting off.
    My knowledge of boilers isn't great so any suggestions appreciated.
  2. king of pipes
    Could be pump failure so a GSRI is needed theres not anything you can do yourself i am afraid . Cheers kop
  3. Adam_BL
    Adam_BL New Member
    Thanks for the reply. How much should I expect to pay to get the pump replaced, if that does turn out to be the issue?
  4. king of pipes
    Such a variation in parts costs but i would think no more than £250 fitted . But as i said a engineer is needed to check and replace if needed . Kop
  5. jtsplumbing
    jtsplumbing Plumber GSR
    Because of cost of parts ! and you may have more than one fault your best course of action is to call out Worcester on a fixed price repair, you can spread the cost if money is tight
  6. scott_d
    scott_d Plumber GSR
    Try the obvious first
    Vent the radiators and check you have pressure
    • Agree Agree x 1
Loading...
Similar Threads - Worcester problem Forum Date
U7 fault code Worcester 37 cdi combi Gas Safe Registered Plumbers Only Jun 4, 2018
Worcester heatslave 2 exterior combi Oil and Solid Fuel Forum May 16, 2018
