Discuss Worcester Heatslave 12/14 - How do I rebuild pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scaily
Hi
I have a Heatslave 12/14 that has lost it's pressure - I have no idea how to rebuild this and cannot work it out from the instalation/servicing manual I have. Help greatly appreciated :)
There should be something that looks like this......
somewhere on your heating system, it may differ slightly from the picture, but opening the valve(s) will allow mains water into your heating system and repressurise it.
Hi R1cky
Maybe I am being really dumb, but I have had a good look at the boiler and cannot seem to find anything resembling what you have shown above. . . there is a Grundfos Super Selectric above the pressure gauge on the what appears to be the flow of the water through system - would this be anything to do with it. It has a simple dial that appears.s to have been turned before?
The filling loop was never fitted inside these boilers, they are fitted externally somewhere near the boiler.
Have a look around the pipework leading to the boiler, as Kimbo said, it won't be fitted to the boiler itself.
The lack of pressure could be a symptom of a bigger problem. i.e leak, expansion vessel or pressure relief valve. You might want to consider getting out your boiler engineer. Whilst he's there make sure you find out how to top the boiler up.
Reply to Worcester Heatslave 12/14 - How do I rebuild pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a recent visit by a plumber (as it seemed to have dropped and was hovering between the green and red zone) . A few days later I turned the thermostat down...
Help Please We have a 2005 Worcester Bosch Oil Heatslave 26/32 that is fitted with the optional timer. Recently we have a problem. To get either the heating or hot water to switch on the timer has first to be set for both to be ON but this just prepares the unit as neither will switch on at...
Worcester Heatslave 12/14 Had a plumber out for a suspected diverter valve problem. He changed the top part and left. Next day he said the brass part might me a bit sticky, so he changed that. Now I have heating and hot water. Unfortunately the hot water comes out scalding for a short while...
Desperate from Wales
M
Hi all. I have a 20 year old Worcester Bosch Heatslave 12/14 Oil-fired I'm getting about 20 seconds of hot water, then the boiler won't fire. I can crank the HW dial right up and it'll fire and give me another 20 secs of hot water. It won't fire again with demand from the tap. It was losing...
