  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Worcester camray utility 25/32 system - oil... in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Aqua Tech
    Aqua Tech Guest
    Ok been having a nightmare with this old system, as i posted a week or so ago. Getting there with it slowly, but the boiler has now started to play up.
    on start up everything kicks in as it should do (or so it seems). fan runs, and oil is getting through. Gave it a good service anyway, as could see it had never been done in the five years its been in. But it seems to just pulse when it shouls actually fire up, and keeps doing it. Just when u get frustrated with it it kicks in. Lasts for a while, stops and starts pulsing again. Over the weekend now it has got worse and is not firing much atall.
    Called worcester and spoke to the senior engineers, and they said "not a clue sorry, we cant help"!
    Its got me 'baffled', am I missing something simple? or is this going to be another headache???
  2. dontknowitall
    dontknowitall Guest
    What are the FGA readings?
  3. Aqua Tech
    Aqua Tech Guest
    Cant get it on long enough to get a result... Whatis your thinking ?
  4. dontknowitall
    dontknowitall Guest
    I was wondering if the CO was really high.
    Have you tried a new pump? They're a frequent cause of problems.
  5. kimbo
    kimbo Guest
    When you say pulse does it fire, go through the sequence. It may be recycling its own exhaust gases, I presume it is a balanced flue, disconnect the air snorkel and see if it does it then, it could also be overaired. Then I would be looking at the solenoid but it depends what burner is on it.Try what I said first.
  6. Aqua Tech
    Aqua Tech Guest
    we have put a new pump on the heating circuit as it was knackered, if your talking oil pump, that seems fine. are you thinking that the flu could be
  7. dontknowitall
    dontknowitall Guest
    What pressure have you got on the oil pump?
  8. Aqua Tech
    Aqua Tech Guest
    yes is seems to go through everything as it should, and yes it is. Will try that... thanks
  9. MattWeth
    MattWeth Guest
    Broken shear pin in the oil pump?
  10. Aqua Tech
    Aqua Tech Guest
    it was good, but dont remember the reading. Was checked though !!!
  11. Aqua Tech
    Aqua Tech Guest
    oil getting through fine.
  12. dontknowitall
    dontknowitall Guest
    I'm not suggesting you didn't check it! Honest!!! Just wondered whether it was set for the correct nozzle and/or if it was holding it's pressure constantly. The way you answered the fga question (which I admit was a bit of a trick question) told me you knew what you are/were doing. I was thinking of what I'd be looking at.
    Kimbo has some valid points though. I had a boiler with these problems but the customer decided to condemn it before I spent more time looking for other solutions. (I had been looking at the flue and air settings and when I changed the oil pump it helped, but didn't cure the problems.)
    (And I'm not trying to pretend that I know much about oil boilers either. The trouble is, on the whole, the burners are so reliable.)
  13. Aqua Tech
    Aqua Tech Guest
    HaHa, tricky...
    this is there third boiler in ten years. Other guys just chuck a new boiler in and run without even cleaning the system. We flushed it and it was really bad, never seen one as bad.
    will try the air flows and see where this takes me.
  14. dontknowitall
    dontknowitall Guest
    The one I changed was around 15 years old and the baffles I'd replaced the previous year buckled.
Loading...
Similar Threads - Worcester camray utility Forum Date
Worcester Bosch G3 unvented course Plumbing Forum Wednesday at 7:45 PM
Worcester Greenstar Heatslave 12-18 Rad Capacity Central Heating Forum Wednesday at 11:33 AM
Expired Worcester warranty and which magnet filter? Central Heating Forum Jul 12, 2017
worcester flue length Gas Safe Register Forum - Public Forum Jul 6, 2017
Pump Problem on Worcester Heatslave Oil and Solid Fuel Forum Jun 21, 2017
Bosch Worcester 24Si II - boiler doesn't ignite Central Heating Forum Jun 18, 2017
Worcester Greenstar 24ri - Possible airlock? Gas Safe Register Forum - Public Forum Jun 16, 2017
