Discuss Worcester Bosch Heatslave 20/25 - Service Life in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bill Keir
I have a Worcester Bosch Heatslave 20/25 oil burning boiler - It was installed in or around 2004.
I have had the heat exchanger replaced, and the expansion vessel, and a few other bits;
but I'm wondering what the normal service life of a boiler should be?
Is it past its ‘sell-by date’?
Thanks for reading
cheers
Surprisingly tough boilers those Worcester Bosch heatslaves despite their list of parts and at 12 years old it isn't ancient. But who knows if boiler will leak, or lots of expensive parts need replaced.
I prefer ideally to have a heat only oil boiler and an unvented cylinder, if all suitable. Less complex and value for money and good flow rates where possible
The old heatslaves are tough beasts. Many about the 20 year mark still going strong. All the older boilers are far superior to their newer counterparts. Can't see much of the new tat lasting 20 years.
Unless it's costing you a lot of money I would keep it.
Plainly I'm new to this, and appreciate the assistance - However, for some reason that I don't understand - the replies I've made to both the above comments do not appear in the thread? am I getting something wrong? cheers
As your under 10 posts there prob stuck in the moderator que
Reply to Worcester Bosch Heatslave 20/25 - Service Life in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a recent visit by a plumber (as it seemed to have dropped and was hovering between the green and red zone) . A few days later I turned the thermostat down...
Noticed today that the ground looked damp around the outside of our Worcester Bosch Heatslave 25/32 External Boiler. Took the cover off and warm water is pooling in the base of the unit. Can't see an obvious leak and all the components are dry. I'm guessing it's the thermal store leaking. Is...
2K
Help Please We have a 2005 Worcester Bosch Oil Heatslave 26/32 that is fitted with the optional timer. Recently we have a problem. To get either the heating or hot water to switch on the timer has first to be set for both to be ON but this just prepares the unit as neither will switch on at...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud clicking/knocking sound that lasts about a minute, stops for 20-30 seconds and starts again. It seems to happen at night, starting in the evening...
