Discuss Worcester Bosch combi timer issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a WB combi boiler. We never use the timer which is the mechanical type on the lower front of the boiler but have it set to constant and use room sat to turn it on and off when required. This method of use suits us well. I noticed recently that the constant setting has stopped working and it operating in timer mode even though the switch at the side of the clock face is in the constant position. It's no problem as I have just set the time pegs so it's on all the time. Is this a common fault. Is it worth changing the clock. Will changing the clock solve it although it tempted to leave it as it is.
Thanks in advance for any replies.
If you only use it on constant get a gas safe engy to disconnect the timer plug, will be on 24/7 then and you can just use your room stat
Or you can replace the mt10 clock (about £50 plus fitting)
Reply to Worcester Bosch combi timer issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
