Discuss Woodley, Berks. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rpm
Subscribed
Been contacted but can`t do it so posting here hoping to help someone.
The job is to remove old toilet only Saniflo in a bathroom and replace it along with around 6ft of 21.5mm white waste pipe and join new pipe to existing 32/40mm solvent weld pipe. Everything including electrics is under the floor in one room and the floor is sections of 3ft square ply. Shouldn`t take more than 3hrs. He doesn`t have a regular plumber so it might lead to other work as well.
Pm me any questions or your phone number and I`ll pass your details on to the guy.
Reply to Woodley, Berks. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing with it as a matter of course. If I'm wrong can someone let me know and I'll shift it to a better place.] I have a condensing boiler installation...
Hi, I have an opening on the 'manifold' (I think that's what its called) on my soil pipe. It appears to be a non-standard size - about 51mm internally. I'm trying to connect a 40mm floplast solvent weld pipe, and can't find a boss adaptor that even nearly fits. I can't cut a new hole above...
Morning All, Just after some advice as I have been asked to plumb in a sink and washing machine waste for a new kitchenette. The other side of the stud wall shown is the bathroom, with the toilet attached to the soil pipe bottom right and a small basin attached to the 32mm waste. The wall is...
2K
Hi I fitted a bath/shower 12 years ago and a few months ago it developed a leak. It was basically at a coupler on 40mm solvent where my new white PVC joined the existing grey PVC. I cut a hole in the ceiling and could also easily view it with the bath panel off but not access it from there...
2K
Hello there! I hope your weekend has started well. TL/DR: Should I replace 90-degree bend with a smaller type to increase the fall from the shower tray? I am replacing a bathtub with a 1500 X 800 Sonas shower tray which I will place on 4-inch blocks, probably with some 18mm marine ply on top...
2K
