Discuss Wireless Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
David66316
Biasi 24s
Timer control switch is broken, so if I fit a wireless thermostat will this over ride the switch and enable the user to control the heating from the wireless stat?
cheers
you mean the selector below the mechanical clock, ? if its wired in correctly and the old clock either removed or fixed in constant posistion then the new stat will control it fine
Yeah, but the mechanical clock is broken , no switch there atall so could you wire it into the frost thermostat to over ride the mechanical clock? thanks
no into frost stat, just wire it into were the brige in the wiring is on the board it will tell you in manual its the posistion for external clock or thermostat in yourcase its all one so no problem,
i have done this for a customer recently them biasi mechanical clocks are exspensive to replace much better to get a nice honeywell wireless programmer or similar
Reply to Wireless Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have bought an old house in rural France and it has an oil tank and Unical oil powered boiler (Italian I think). Its a beast of a thing but can't find any model info or any plates on it. I want to change the switch and thermostat to a digital wireless thermostat but I'm not sure what I can...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting,. So I have set all the little timer switches to ON and the boiler does work then. Any help or source for a new clock would be great. TIA
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar 18Ri to short cycle. So, the moment it gets cold outside my boiler works for about a minute, then stops, and starts again in about 5 minutes, then...
2K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
