Discuss Winter vs batteries in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Paulplumb
Do you all take your power tool batteries in from the van of an evening to prevent them getting damaged by the cold if indeed that is possible?
Thanks in advance
Just reminded me.
I normally have a bag of batteries and take them in.
I dont know with Lion but i do know they are too expensive to risk
My van goes in the garage every night so never really gets cold. I've never had to de Ice the van in the 8.5 years I've been plumbing.
Take batteries inside of course, you shouldn't be leaving powertools in overnight anyway.
Heat is more a concern but in the cold (below zero) charging and heavy discharge/use is not a good idea as it can cause damage to part of the batterys electrodes i believe (some plating over of parts i think).
most lion batterys for powertools will not allow use/charging below zero or above 45 to protect the cells so its best to store in the house in the winter and store in a warm place while at work. in the summer the oposit may be true, keep them out of sheds, vans if very, very warm.
nope, takes me long enough to climb 30 plus steps to my front door :)
I just leave in van. Used to park van in garage but it's now completely full of stuff, so I just park in drive way
Dont mention plebs.
There'll be hell on just look what hapened to that poor poor politician :D
Only the analyser comes in the house. Only have my combi drill and impact driver in the van. Used to have an issue with my dewalt gear on extended use, the batteries used to overheat and then I couldnt charge them till they cooled down. No issues with the Milwaukee gear though.
Reply to Winter vs batteries in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Love
It's DIY forums like this that have helped countless people fix, repair or replace things in their homes, which helped prevent additional damage and/or save a bunch of money in the process, not to mention that amazing feeling you get once you're done with the repair. So thank you to all the...
C
Hello all, I'm preparing an estimate for a bathroom renovation in a block of flats. As always I'm trying to flag up / plan for and cost as many possible unknowns as possible in advance. One thing that I've not seen before is the ~50mm pipework connecting into the soil stack (see picture). My...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
I would like some guidance regarding the Worcester CDi 29 Classic boiler. According to the manual it has a holiday mode and frost protection mode for when away for a period of time such as a holiday, both of which disables the central heating system and both require it to be set manually. I have...
Sorry for asking a silly question but does anyone know how this seat comes off ? Have had advice from local plumber but even he couldn't see how to do it. The only thing that seems possibly relevant is that each bearing point has two very small rectangular gaps, one at 8 o clock and one at 4 o...
