Discuss Whistling Outflow Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Duane Pipe
Hi All, glad I found the forum and hope you can preserve my sanity! Apologies in advance as I am a 'civilian' and may well not get the technical aspects right so please bear with me!
We had a new kitchen fitted three years ago. The outflow from the sink is 43mm pipe going through the wall and directly down into the drain outside and on to a septic tank. When the wind blows from the west (i.e. along the wall) there is a high pitched whistling from the outflow pipe which is very loud and distracting in the kitchen. If the terminal segment is removed and a bag placed over the open end of the outflow the whistling stops so it's definitely coming from the pipe.
I have tried cutting notches in the bottom of the pipe to alter it's shape, extending it down to just above the water line and putting a virtually airtight cover over the drain to prevent the wind getting in. I've tried wrapping plastic windbreak material over the end of the pipe and even cutting up a flower pot to act as a kind of cowl over the drain - and nothing works!:-(((
It seems to be acting like a musical instrument but I can't seem to find a way to stop the wind causing it to resonate. I've also checked to joints and the integrity of the pipe so there aren't any hidden gaps/holes to cause it. Presumably I can't extend the pipe to below the water line in case of siphoning back.
It's driving us nuts. Please help!!
Thanks in anticipation.
Thanks for your reply. Yes, it"s all been professionally done.
Make a u bend in the gully
Thank you all for your replies. I regret I couldn't get the plant pot idea to work but I managed to bodge up a temporary u bend with pond hose and so far it seems to be working! Thank you very much from me and my poor, long suffering wife - and for giving me back my kitchen!
Reply to Whistling Outflow Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone shower in the garage which has been removed. Unfortunately the pipes are only 1.5" on that side of the house since there's no bathroom and the house is...
Hi Just removed an old toilet and fitted a new push button cistern one. I had to re-route the supply water pipe over the waste pipe coming out of the back as i had to use a swan neck one to line up with waste hole in floor,and the water pipe didn't fit past waste pipe. I cut the supply pipe...
  • Locked
My kitchen waste pipe discharges into a pipe going to my soakaway. It has now unsurprisingly become blocked (about 6 m from the drain). The soil pipe from the toilet to my septic tank passes underground about 1 m away from the end of the kitchen waste pipe with a good enough slope for the...
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical, carpentry it's been never ending. The house was built by Barratt Homes in the year 2000, it is a 3 bedroom house called a Palmerston, the CH/HW system is a Y...
5K
In my kitchen, I have a dishwasher waste pipe - it is routed into black pipe that runs from the roof (guttering) to the ground (outside). Normally this is fine, but if I get heavy rain, the pipe that both the guttering and DW waste pipe are routed into fills faster than it can drain away, and...
2K
