Discuss Whining from a new Vailant Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
First a Hello from a new member.
I wondered if any of you experienced heating engineers have heard an intermittent whining noise coming from a new Vaillant ecotec plus 637 system boiler?
Fitted (complete new system) June '16, S.Plan -two CH zones and one HW (unistor 210), external by-pass & TF1 fitted, flushed and commissioned as per tech. Has run like a dream until November '16 when, once a day at aprox 1.30pm there is for couple of minutes a whining noise from the boiler. Since then the system has be re-flushed and the by-pass adjusted, but the noise persists.
Vaillant haven't answered my emails, so I thought I'd ask some real people, any pointers would be much appreciated.
I have a video from the clients phone, but I can't seem to attach the file.
Cheers
R.
When does the noise happen when the boiler is on when it's fired etc ?
Hi again, noise happens when boiler is running/fired then sound goes away as boiler shuts down. No nothing like a trombone, sounds quite high pitched. We thought there maybe a restriction but we have re flushed with care to no avail. The client is middle eastern and likes it blooming hot, so the system is peddle to the metal nearly all the time, shouldn't make a difference though.
R.
How old is the boiler ?
Under Warranty then ?
Get Vaillant eng out
My advice, make sure you are there for the argument !
Whenever I send MF Engineers to customer, I always ask customer to ring me at the first sign of a fob off, If I'm close enough I will go and meet the Engineer if not I will speak to them on the phone.
Okay will do, just thought it might be something simple or something we have overlooked.
Many thanks for taking the time to reply.
R.
Can you get the installer to look at it and ring vaillant
If not you may be charged
I had a problem like this on a new Vaillant install. I don't know if you are having the same noise as i did.
Yes, commissioning procedure followed, Fernox F3 cleaner used, Fernox F1 added, paperwork filled in, all registered with Vaillant.
R.
Is there a print off of the fuel gas analyser results if there is what is the co 2 reading gas valve may need adjusting grs engineer needed .
Reply to Whining from a new Vailant Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester Greenstar gas boiler circa 2017. There has been a noise coming from the boiler which resembles running water, I have checked the system pressure at 1.5bar and the relief valve but the noise persists unless a hot water tap in the house is opened then it stops for a period of...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig cupboard & a megaflo (no tank in loft). However the exisiting boiler is Vaillant ecoTEC 4xx boiler - which is satated by vaillant as an "open vent" boiler...
Hi, Is it normal/usual or acceptable for there to be this much metal filings in a heating system following a new boiler installation only 5 weeks ago? A supposed Chemical Flush was completed as part of the installation process.
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this could be as a result of us noticing the sound more when there is less environmental noise). Unfortunately, it is severely disrupting our sleep, so we...
