Discuss Which air source heat pump? in the Renewable Energy area at UKPlumbersForums.co.uk.
Thread Status:
  1. willing2learn
    willing2learn Plumber GSR
    Hi guys, my wife and I are doing a self build. I'm a GSR plumber. There's no gas in the village, we were toying with the idea of going down the pellet burner root. But are now swaying towards an air source heat pump, with solar geothermal and a log burner in the lounge.
    I've never installed a heat pump, and not sure which one to consider/avoid.
    Any views on this people?
  2. ecowarm
    ecowarm Guest
    Google Earth save products, give them a ring or email, very friendly and helpful people. Ask about the Ecocent hot water cylinder, and their knowledge of heat pumps is second to none
    • Like Like x 1
  3. willing2learn
    Thanks for that, I'll check them out. Just having a look at the new Samsung EHS mono.
  4. CMcM
    CMcM Member
    Mitsubishi! cheap, chearfull and easy to install.
    Can use it to feed your heating (underfloor or rads) directly or sent it to a buffer.
    Pellet burners/ wood burner etc - to much hassle, cleaning out etc every so often depending how often u use it.
  5. Nostrum
    Nostrum Plumber GSR
    Any thoughts on the dimplex range?
  6. xpertbert
    xpertbert Guest
    My choice would be Nibe all the way. Not cheap but when installed and set up correct they are te best. Back up and customer service very good to. Mitsubishi have zero help in technical and service and there product is not a patch on there's.
    • Like Like x 1
  7. fergie656
    fergie656 New Member
    Daikin altherma or the mitsubishi ecodan
  8. willing2learn
    Bit of an update. Went to Earth Save Products and had a good chat with the guys there. Very impressed with the Ecocent Cylinder. So looks like I'm swaying towards one of their ASHP for underfloor heating downstairs and some of their low temp rads for upstairs. The ASHP doesn't have to do the DHW as the Ecocent cylinder takes care of that.
    Edited to add, I'll be fitting a buffer tank too.
  9. markfxy
    markfxy Plumber
    If you're fitting an ecocent you'd best buy a nice warm coat as well cause it'll suck the warm air out of you're house and dump it outside
    • Like Like x 1
  10. ecowarm
    ecowarm Guest
    Markfxy, the ecocent can take air from outside, or warm moist air from a shower room or kitchen and then return cool fresh dry air somewhere you may need it
  11. willing2learn
    Hi Mark, do you have any experience with the ecocent cylinders then? The plan was to have the vents over the showers and near the log burner, and maybe on in the utility room.
  12. eaton
    eaton Guest
    Samsung he's is very good, and great price, hitachi yutaki again very good, Mitsubishi hugely overrated and priced. Nibe I wouldn't go near as they're like a closed shop and just want you to pay for training etc, I'm Dimplex accredited again ok but controls are a pain. I'd go with Samsung, give Grahame at freedom heat pumps a call
  13. Eco Heat
    Eco Heat Guest
    Husky Air Source are one of the best new comers and very competitively priced. We typically can supply and install one for around £1500 less than Eco dans etc.
  14. quality
    quality Plumber GSR
    Danfoss AQ is a good performing unit but not cheap
  15. eaton
    eaton Guest
    I'm the same can supply and fit for nearly a quarter less than the Ecodan quotes out there
Loading...
Similar Threads - source heat pump Forum Date
Central heating not working Gas Safe Register Forum - Public Forum Yesterday at 3:18 PM
Ravenheat cs80 boiler. Cannot rest boiler Central Heating Forum Yesterday at 12:35 PM
Thread Status:
