  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Where are my hot and cold water stop valves (stop cocks)? in the Water Regulations area at UKPlumbersForums.co.uk.
Thread Status:
  1. Valvequestion
    Valvequestion Guest
    I've been wanting to find out where exactly the stop valves (stop cocks) for hot and cold water are. Hopefully one of you can help me with this!
    I took some photos and numbered the valves - here's the link: Where are the hot and cold water stop valves? - Album on Imgur
    Could you please help me? Thank you so much!
    Emily
  2. Howsie
    Howsie Plumber
    2 Turns your hot water off by stopping cold water coming into the bottom of the cylinder.
    I can't really see what the other valves are doing from the angle of the photo. Turn them off one by one and see when your bath tap stops running.
    Do not have your heating on when you do this.
    When you put them back to their original position, give them a half turn in the opposite direction as this will stop them from sticking.
    • Like Like x 1
  3. GasmanxxxR1
    GasmanxxxR1 Plumber GSR
    Think 2 is a balancing valve not the hw off
  4. GasmanxxxR1
    Possibly 3 is hw off, hard to tell
  5. quality
    quality Plumber GSR
    Turn them all off that may stop the water
  6. Dotty
    Dotty Guest
    Please register with us and start a new thread to receive an answer to your question.
Loading...
Similar Threads - Where cold water Forum Date
Where Is The Cold Water In Filter On Turbomax Plus? Central Heating Forum Feb 9, 2016
where did ... ????????? Plumbers Arms Saturday at 9:03 PM
Where oh where is this air coming from? Central Heating Forum Wednesday at 4:04 PM
Where can I get a longer one of these please. It's from a tri flow tap with BW100 filtration system Plumbing Forum Jul 11, 2017
Gas is where the work is these days - true or false? Plumbing Forum Jun 17, 2017
Can't find a 26mm tap aerator anywhere? Plumbing Forum Jun 6, 2017
How many is enough and where to fit valves Plumbing Forum May 11, 2017
Thread Status:
