Discuss whats this fitting ...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
paulyoung666
...... its the hot water outlet from my cylinder , i was hoping to fit a surrey flange but it aint 1" screwed iron ......
which by the looks of your link is going to be 3/4" not the 1" i need to fit a surrey flange , thing is though , it doesnt appear as though the threaded piece will come out of the tank top , it almost appears to be formed from the copper of the tank itself , is that even possible .....
If it's formed from the cylinder or formed from copper and brazed in, it should be BSP.
Unless the fitting was supplied by the cylinder manufacturer in which case they would have to have supplied a straight connector as well as an elbow,, seems unlikely.
Any makers label on left on the cylinder, it'll be round the back just where you can't see it or reach it or get a camera in to view it??
its an albion supalag green , tried there website with no joy though :(
Cheers, when I looked at it, it didn't look like 1"bsp, I think I will get a socket and try it on the threads ......
Reply to whats this fitting ...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am fitting a new shower valve, it has 1/2 inch compression female in/outlets. I am using a 1/2 in ch to 15mm elbow to get me into my copper pipe network. Should I use a 1/2 - 15mm adaptor with a flange or without a flange? What is the flange for anyway?
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I doing reading those!), it reccommends connecting to the inlet and outlet using SS braided flexible hoses. Nothing wrong there me thinks. I dropped...
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what fitting can I get for it I would like a flex as it will easier for me when installing the new toilet
O
im a DIYer remodeling my master bath. long story short, after tiling my toilet flange is too high. im aware of all of the options to repair, but we could use a new toilet anyway..so my question is, is there a toilet made that will fit a high flange? or do I need to just suck it up and repair it?
