Discuss what size expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
holedoctor
hi
i am installing evac tubes BUT system had 40 hp tubes with 8 litre expansion vessel supplied and i got another 30 tube panel to add to system. it is piped in 22mm copper (about 23m of pipe) i am running it through my existing coil (was on oil burner) of a 250 ltr copper insulated tank and i am going to heat dump via solar coil into 1000ltr buffer tank.
so to my question would an 18ltr expansion vessel be good enough for a 70 tube system as i have one to hand and how do you work out the sizeing of the vessel.
thanks
Reply to what size expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from the loft water reservoir tank (which also feeds the cold water taps in the bathroom & the WC cistern). There is an expansion vessel attached to this...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
Has anyone got a good rule of thumb for sizing an expansion vessel for a central heating system. A combi has a 8 litre vessel. And will deal with the expansion of say 8-10 rads. Could one use this as a ball park figure and multiply up from there Obviously pipe work to take in to account 22mm...
2K
Hello Everyone, I have customer with solar that doesn't seem to be working so only gets 1/2 a tank of hot water which is heated by the central heating system. She can't find a company to come out and service the wet solar system and she is looking at getting loft conversion in the future will...
I have an Elson Sapphire double feed indirect hot water tank and I need to drain down the system to move some radiators. Would anyone be able to offer any advice as to the correct drain down and refill procedure for this tank? It is a self contained boxed and insulated unit with a single cold...
1K
