- Messages
- 5,167
Hi Guys, what would you recommend, house has 20 litres a minute with 18 litres working, only one bathroom and will not change. Cheers
Discuss What size combi boiler?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
LogicVaillant?
You mean a vogue 32?
any chance of a restriction in the existing 22mm?
Seems a big loss over that length of pipe
Thanks chaps. The original combo was 30kw so I put in a 32. Now I replaced 10 metres of the original 22mm gas pipe with 28mm working back from the boiler. Was expecting this to give it a nice boost. Well it didn't, only getting 14.5 mb working at appliance with 21 at metre. No other appliances. About 8 metres of 22mm from meter to 28mm. Gutted
Did you do a working gas pressure at the meter and at the boiler gas valve if so what were they it seems a big drop over that distance , you would have been better to upsize off the meter in 28mm as much as you could ?isolate and disconnect the gas meter turn it upside down on a dust sheet to see if there is any rust or debris in it . good luck kop
is that at the gas valve or the actual inlet to the boiler as some lose quite a lot of pressure at the valve thats why some put a test point on the isolation valve now
That is strange ISO valve fully open ?
And I would cut a test point in below the boiler
Yep, gas rate spot on. Analyser was within spec but ideals always have high co of 200ppmAgree with Shaun, Did you gas rate it?
Reply to What size combi boiler?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
