Discuss What Isolation valves are best in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello,
Is it ok to use a full bore isolation valve to isolate a hot and cold feed to taps or should I use a service restricted bore. I’m thinking about using a full bore with a handle as my default as I find that most of my customers struggle to muster up a screwdriver to isolate the water when there are problems. As a novice I’d be interested in what you seasoned plumbers think.
Regards Tezzer
Depends if the supply is tank fed or main supply.
-from tank you better use full bore so the flow isn't restricted any further
-main pressure supply is okay with both
You can get cheaper handle operated service valves than that. Make sure it has British or European standard number on it for quality.
Reply to What Isolation valves are best in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
