Discuss What is this fitting? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pressure relief valve, and you had best get a heating engineer in to find out why its leaking as a fault elswhere may be causing the problem.
Ah I thought it looked like a pressure release. Thanks for letting me know. Reason it is leaking is due to age/corrosion I think. The heating isn't even turned on and the pipes are cold.
Heat destroys the seal on those relief valves. Looks like a 3/4" valve. A better relief valve would be the type with a round head on them, often red & they can be got with different pressure limits.
Yeah!, stick a six bar prv in and it will never leak again.
The valve pictured was originally fitted to open vented gravity systems.
As has been said, get someone who knows about systems older than 10 years to sort it out.
Reply to What is this fitting? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
