Discuss What in the life is this? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Harvest Fields
Subscribed
Can anyone please explain the pipework on this cylinder to me. It’s got a mate of mine scratching his head and I have never seen one before in my life. I understand the concept but the pipework and configuration make no sense to me.
blending valve on the top connections to stop scolding water temps
Looks like some strange type of het store But never seen anything like this, is this in an ex council house ? cos they did some very strange systems
thermal store ?
figured it out :D
Blending valve pipe with shock atrestor on hot out
Pipe going to bottom of cylinder cold tank into tmv and cylinder
Left pipe coming out of tmv blended hot
Defo a thermal store mate
figured it out :D
The one going into the TMV and bottom of cylinder is mains pressure mate. (Apparently)
Yea so coil is under mains pressure normal so that means he's got high pressure at the hot tap ?
Two options either swap for another thermal store or change for an unvented and run a discharge
This in a hard water area seems lots of corrosion on some fittings, where does the silver pipe behind the pump go ? could do with a couple more photos from a different angle
No idea mate working with what I have. It’s for a mate. Said I would post it here and get everyone’s thoughts.
Reply to What in the life is this? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
