Discuss What fittings Required in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Archie
Hello, I am setting up a Reverse Osmosis system. I am trying to figure out what this picture consists of.
The black pipe is 4mm but need to know what the other two fittings are that attach onto the PVC pipe itself..
Regards
Archie
ok......... :eek: a Reverse Osmosis system is normally a little hard-core, if your planning it for drinking water why not just use a carbon based filter as they shift most of the normally nasties in the water.
I mean i used a Empura filter tap supplied by Bristan and that did job easy and was very easy to fit.
Hope this helps. :)
The one below is a plastic screwy on thingy going into a bigger screwy on plastic thing.
Hope that helps.
It looks like a push fit fitting of some sort and then as NickH says "plastic screwy thingys" to get to the appropriate size.
Mark
I've been looking at this picture again.
It looks like a push fit to 3/8 adapter coming in to a 1/2 and thne in 15mm supply pipe, something similar to filters tap offer by just about everybody.
I Still think sticking a filter tap would be the easier way.
Reply to What fittings Required in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
