1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Dismiss Notice
Couple of important things to note. 1. We use Cookies, deal with it. Every website does. 2. Nobody but a currently-registered Gas Engineer should be touching gas or gas appliances. Don't mess with gas at all.
Discuss What concealed thermostatic diverter, body jets, rain and hand held should l fit? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. fletcher7751
    fletcher7751 New Member
    Hi all
    I will be fitting the above for a client, she had bought a set from an online specialist, see other thread, best thing they did was a refund! Foreign HC inlet thread, valve faceplate could not be secured (relied on silicone), body jets had backnut which was inaccessible when tiled and instructions were poor.
    In your experiences, what manufacturers would you recommend on a budget of around £400?
    Pfister in USA look well made, but can't find UK stockist.
    Grohe are well reputed, but around three times budget
    Just need good quality, with instructions rather than a Krypton factor test, that can be fitted leak free and serviceable in use.
    Not much to ask...
    Cheers
  2. Plumbstar Tom
    Plumbstar Tom Moderator Plumber
    for what you want you need to go to one of the decent suppliers and for that reason i don't think you will get close to your budget
  3. fletcher7751
    Thanks Tom
    The client thought it was a decent supplier, double the ebay cost, but you have no idea where it is sourced or their mark up. What do you think would be a ball park for that set up?
  4. Plumbstar Tom
    maybe around £600+
    Make sure they have decent water pressure for the body jets and they are plumbed in correctly, seen too many where all the water comes out the top two and dibbles out the others
    Also check how they want the diverter set up working, what controls what etc
  5. fletcher7751
    Cheers Tom
    Pressure fine flow rate 18 l/m, so good too
    Got their requirements on controls, they never realised it would be rain and jets on one, hairwash on the other, and can't have all three on at once.
    Doing a 22 pressure loop to prevent last jet dribbles!
    Pfister in USA do a good range so you can pick and mix, good prices too....not here though.
    First thoughts were Grohe and Bristan, but the kits don't lend to bespoking a system, and Grohe costs are Bentley money!
    I'll keep looking, used to fit a lot of Pegler taps and TMV 2's will see what they offer.
    They were good quality, sturdy and spares were always there if needed.
    Would prefer to get separate components rather than a kit of misfits from god knows where.
    What would be your go to manufacturer supplier?
    Cheers
  6. Plumbstar Tom
    You can do what you want with decorative stop cocks and separate diverters if you want
Loading...
