Discuss Wetwall self install in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Wrighty8
    Wrighty8 New Member
    We have decided on this and the panels are coming on Monday and I was wondering is it best to fit before the shower bath goes in? ( thats in the spare bedroom!)
    What is the best adhesive to use, someone said Gripfill?
    Any other tips?
    Thanks all
  2. scott_d
    scott_d Plumber GSR
    Use what ever the manufacturer recommends
  3. Wrighty8
    Wrighty8 New Member
    Ok will do, says this in the install notes,
    "External grade 'high grab
    adhesive' such as GRIPP FILL.
    Any other thoughts on my other points at all?
  4. ShaunCorbs
    No shower in first have you got all the trims for corners and on the tray ?
    Also depending on size of panels there not easy to fit
  5. Wrighty8
    Wrighty8 New Member
    Cheers Pal, yes got all the trims ordered - 1 internal corner, 2 x end, 1 join and the trim seal for around the shower bath.
    Panel sizes are 2400mm x 1200mm but will not need the full height as I plan to use the offcuts hidden by the Bath elsewhere.
    It is a L shaped shower bath that will be going in with the shower above at one end installed thanks to you and other helpful chaps on here :)
  6. townfanjon
    townfanjon Trusted Plumber GSR
    Do not use gripfill mate
  7. Wrighty8
    Wrighty8 New Member
    How come? it actually names that on the install info o_O
  8. scott_d
    scott_d Plumber GSR
    I never find the original grip fill very sticky, seems to skin over too fast
    • Agree Agree x 2
    • Like Like x 1
  9. Wrighty8
    Wrighty8 New Member
    Ok... looks like that's out! suggestions for a decent high grab for this purpose please?? guessing it has to be waterproof and solvent free.
  10. ShaunCorbs
    And can eat into the panels I've heard
    • Like Like x 1
  11. townfanjon
    Nobody on here rates it pal , best one is “ sticks like **** “ screwfix is best , just test a bit first or check with manufacturer.
    • Like Like x 2
    • Agree Agree x 1
  12. king of pipes
    Gripfill works ok but you need to brace the panels with timber batens , other adhiesves can be used as below not a fan of the trim on top of the bath looks nasty unless done to perfection , i prefer to sail the panels past the bath then fit the bath against them with a neat silicone bead around the bath but each to there own good luck with it . kop
    • Like Like x 1
  13. Wrighty8
    Wrighty8 New Member
    Cheers all, I'll be sure to give Gripfill a swerve!
    I am tempted to get the £1 in toolstation, gets decent reviews but I'll check out sticks like s***!
  14. andyplumber
    andyplumber Plumber GSR
    I would not use grip fill it skins over before you fix the panels, pink grip would be best to use, i had a job before christmas manufactures supplied grip fill £80 worth and would not grip ended up buying 24 pink grip on top of what i already bought
  15. townfanjon
    Its only slightly better IMO lol
Loading...
Similar Threads - Wetwall self install Forum Date
Looking to purchase Viper books and self study workbooks. Any good? Gas Safe Register Forum - Public Forum May 5, 2018
