Discuss Weathering wires/cables through pitched roofs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
justlead1
I have had a couple on inquiries for cable flashings. From companies fitting PV. panels. It would appear banging a hole through slates, passing cable through and adding silicon is not excepted by some Clerks Of Works. The image is a flashing that i have developed and made for existing clients. Is there a market for this item? Your feed back would be much appreciated. image-cable-weathering.jpg
Hey justlead1 looks like a very nice item I would suggest you register yer self on the electricians forum and ask them as there are a lot of guys doin PV on there
Looks just the job, what are you retailing them for? just in case!
Hi all thanks for the feed back, quite positive. The cost is likley to be around a score. i have listed some benefits below that i will use for marketing. Any additions would be gratefully received.
Listed below are a few points to consider.
* I can supply with any size base and outlet.
* By using code 4 sheet lead wind lift is overcome.
* The nature of lead will not cut into cable/wire,
* The longevity can be in access of a century.
* Dresses well to any undulation of the roofing materials.
* Within the skill base of most when trimming is required.
* Allow ventilation around cables but remains weather tight.
* Adding or removing cable during the life of the building becomes easy.
* Made for purpose. As opposed to drilling a hole and silicon around cable.
* Supports the lead working skills of cottage industry.
* Can be 100% recycled in the event of removal.
* Has the aesthetics associated with roofing.
we all know one group of parasites who would be very interested in these...
Did ya take this project any further justLead ?
Hi Thanks for your posts quite positive. I have had some intrest shown from large power suppliers, however the rates they wish to pay are not in keeping with my own. I will keep you posted.
That may be true Eco, but you've not seen my lead welding.....it looks nothing like that. Blobs and holes everywhere. You mean it's supposed to look like it does in the photo above? :wacko: Oooooh.
Thanks for your comments Gentlemen. I will keep you posted on any advancement regarding the product. (Thing could have been easier, as my father left me a million. But forgot to tell me where he left it)
Good Luck
Reply to Weathering wires/cables through pitched roofs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need some help from the internet before I waste any more time and money trying to fix air getting in to my central heating! Looking for advise on what to do next, as the 3 plumbers I've used so far haven't been much use. Down in East London, near Romford for what it's worth! Issue summary...
2K
Hi Everyone, Quoting for my first boiler installation with vertical flue going through pitched roof. It is 3 storey house, i am planning on getting a roofer to fit the flue through roof & flashing kit, would you say this would be best way to go about it? Can any roofer do this? and would they...
A number of issues have been raised from a boiler replacement. Boiler not operating and with no pressure. Tile damage Sprawling pipe layout in kitchen (Retrospective view of alternate option when it was found that promise of removing pipes from airing cupboard could not be fulfilled). Battery...
5K
  • Locked
Nmf 3 last post the radiator views 329 replies 19. 5.79% Fixings Ok you've struggled the double panel extended surface radiator into the room ,it's already heavy and when it's full of water it'll be heavier still. As my old. Physics master use to drum in to me "a pint of water weighs a pound...
1K
R
  • Locked
Hey all, apologies for the long post: I've had a new Ideal Vogue boiler installed with a T6 wired thermostat so the OpenTherm is activated as confirmed by the boiler. I also have the outdoor sensor installed but I now understand that when OpenTherm is used it ignores the outdoor sensor...
4K
richardc1983
R
