Discuss WD 40 for silicone removal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
monkeywrenchps
I've had it recommended to me that WD40 is useful for removing silicone sealent to save a bit of elbow grease, as long as the area is properly cleaned and dried using industrial de-greaser wipes afterwards to clean off any residual WD40.
Does anyone have any experience with this? I do have some doubts but it'd be nice if it turned out to be true.
If only it were that easy! (Although I haven't tried it to be able to rule it out)
it's possible that it is the solvents in the wd40 that do the trick, so you would probably be ok with most things that contain solvents imho.
use very sparingly though, you don't want to melt the bath.
ive used it before on a bit that didnt matter ! didnt notice anything but not to say it doesnt work on diffferent types of silicone
Hahaha! Now that is an amusing mental image. *Slow motion* NOOOOOOOOOO!!!!!! *Melt*
The good stuff would eat thru Expanded polystyrene like air fix glue ,
or heat proof radiator paint in polystyrene cup , on posh carpet ! Memories in Slo-mo
It can, but silicone remover from Screwfix is better and less work.
WD 40 DOES WORK. My husband removed silicone EASILY using WD40 on the sealing around our bath, hand basin, and kitchen sink which had not been renewed in the 15 years since we moved into this new house. He sprayed the WD40 on and left for a few minutes then using a plastic recommended tool lifted the silicone, wiped over with Turps and dried it off. The dark places (mildew?) he wiped over with bleach dried off well and then applied new silicone. All is as new as 15 years ago.
It depends on the type and quality of silicone, WD ! WILL NOT remove good quality silicone
You'll find more up to date threads than this in the main Pluming Forum. But I'm reply to this so we bump it up the list and get the pages indexed correctly because of the new update we've had. So just ignore this if it's all old news.
If you do reply, keep it polite and professional. You can disagree with the above posts, and just be professional with your reply.
Reply to WD 40 for silicone removal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
