Discuss Water main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jez
Morning all,
I'm doing a self build and have a 50 mm main into the property(waterboard recommendation!)
Max Water flow is the main aim, I have 2 boilers ( house and pool) and 2 mega flows.
Whats the best way of changing from the 50mm mdpe to copper?
cheers, jez.
get yourself a good approved/water safe plumber and theyll do it right. Cant see then need for a 50mm main in any property, pool or not or 2 mega flows or not, way over the top.
Reply to Water main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains pressure from small hole/crack The outside of pipe (measured with veneer caliper) at 23.5mm Pipe Runs under drive, along side of property and looks to go...
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each apartment for domestic hot water varies greatly in timing and volume. Thus the oil boiler is required to work for long periods which is uneconomical...
Hi everyone, Just wanted some confirmation regarding a PRV fitted to the mains supply in my building. All 6 flats in the building are now connected to the mains water feed supply and the water tanks in the attic have been disconnected (each flat has a combi gas boiler). I can see there are 2...
A
Hi all - hoping to get some advice here on a plumbing issue in our house. When we are showering / filling the bath and another appliance draws water (toilet cistern filling after flushing, tap being turned on or washing machine filling etc), the water pressure / flow to the other appliance...
Azonic
A
