Discuss Water in my Diverter Valve Actuator Motor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi,
I have an Ideal C30 combo boiler and recently lost all hot water, but the central heating still working.
Got a plumber friend out to sort it, who changed the diverter valve actuator motor and also the BOILER DIVERTER VALVE CARTRIDGE. However, we lost hot water again the other day and after checking the diverter valve actuator motor again, it had water in it again, but there is no sign of any water or a leak anywhere else inside the boiler.
It's almost as though water is seeping into it through where it is connected.
Would this affect us getting hot water, but still allow the CH to heat the house?
Any ideas or experience to fix this would be fantastic as don't want to buy those parts again and for it to be wasted
Thanks HW
Its the same problem usually caused by dirt or debris in the heating system very difficult to clean it out before replacing parts , but I think you don't really have much choice these parts will need replacing a long term successful repair depends on how your system is cleaned and protected. Cheers kop
Is that a simple enough job to do? How long does it tend to take to sort out?
We've got one of those magnetic chambers attached to the boiler as well that is suppose to catch any debris etc....thanks for your reply!
Yes it simple enough job but as the guys have said it will pay to change the whole diverter valve not just the cartridge ideal parts are quite reasonably priced, a mag filter will not stop debris entirely your system will need a chemical clean and flush i would allow a days work for cleaning and the repair . good luck kop
Reply to Water in my Diverter Valve Actuator Motor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a heating system comprised of skirting radiators that form part of a loop from the boiler, round the house and back. Some rooms get warmer than others despite closing off the skirting radiator heat vent. They are designed to house the finned heating pipe and a return pipe, the latter...
Hi I have a fully pumped heating system fitted with a Drayton MA1 diverter, after the summer run the heating stopped coming on, so I replaced the Actuator head, however I have found the actuator is stuck on H (Heating), I have turned down both heating and cylinder stat - still stuck on H. The...
Trying to find out exactly what happens when my system boiler is called to supply the radiators and hot water cylinder at the same time. For example today, whilst the boiler was on heating the water, the room stat triggered the boiler to supply the rads. The diverter valve installed in the...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring, probably not been used until recently now it's colder. When heating is called for, the boiler fires up ok but soon shuts down the heater as the...
