Discuss Water hammer/vibrations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PhoenixServices
After some advice guys. Don’t know if I’m barking up the wrong tree, got a property that I fitted a Worcester in a couple of years ago. All been fine until last year when the new owners complained of water vibrations.
The property had been empty before that. I fitted a shock arrestor and it seemed to cure it but it has now returned.
It’s only when you flush the toilet and run a tap at the same time.
Is it worth changing the fill valve on the toilet. Or do I need to re-pressurise the shock arrestor, if so what pressure?
Sorry it’s such a long post.
Do the vibrations happen with both hot & cold water - assumed you fitted a combi boiler.
Or do they only occur when the cold water is being used.
Could be worth changing the inlet valve on the cistern to see if the rectifies the problem
Reply to Water hammer/vibrations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I have been a plumber for 3 years now, I haven't come across many issues with water hammer so I'm not to sure what to do. it happens on the hot pipework, more specifically the hot taps in the bathroom (basin and bath). but it only seems to happen when I open the hot tap to a...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
About 9 months now, started suffering intermittent but frequent hydraulic shock thwacks, sometimes very violent, below Harvey's water softener in mains cold copper pipe. So far, water tank ballcock replaced, kitchen mixer tap replaced, Harvey's serviced the water softener, approx. 5 years old...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
