Rob Foster
- Messages
- 2,083
I am begining to think that I will see the end of gas boiler installation in my life time just as stinkpots are finished in a few years time - what do others think ?
Discuss Watching the dash to electricity from renewables in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I think you need to redo that tightness test, what do you think the alternative will be...super efficient homes with energy recovery that run on body heat?
you may laugh but i once saw a candle being used to heat a room (more of a test / proof on the new insulation )
I remember seing super insulated airtight homes over a decade ago Shaun and yes they basically run on body heat. What I kid at is this or any other future government wanting to do anything about it considering the quality of new builds that are barely fit for purpose.
John Prescott drove the dash to condensing boilers cause Ideal was in hull and he wanted votes - ill considered rubbish that they areIf and when the UK exit Europe don't expect anything to happen too soon or with any planning or foresight, after all it was the UK's adherence to European boiler efficiency standards that has dragged us kicking and screaming to where we are now. Tory governments also tend to be reactive rather than proactive so expect who writes the biggest cheque to have the biggest influence, I seriously doubt that is going to be the environmentalists.
That is where I was thinking - what to train the youngsters in for a bright future The other big one is what use the redundant gas supply network can be put to esp the last mile or so to domestic properties - I know one consultant who is lookin at this alreadynobody will want a house on old fashioned expensive polluting gas soonIf they can find a way to capture the co2 and not let it vent to atmosphere then maybe it can last longer, but how much natural gas is really left and what is a good alternative? Hydrogen? Power stations run on gas would also need to capture all the co2. They are talking 2025 getting rid of coal ones, 2035 for gas powered ones. It does look a little like it will end for NG. Even if it does go Electric and renewables, still needs installed and looked after. Probably most will have to invest in new qualifications for renewables. It may be a time of opportunity not the grim end we might think.
I can't think of anything worse than living in a air tight box the environment is awful inside worked in loads of these, give me a house that can breath any day , i am starting to fit wet system electric boilers in certain properties off grid but it has to be the right construction and usually smaller properties , the boilers are between 9 -15kw max no need to oversize, I expect to see a gradual phase out of gas but can't see it within the next 20years so time will tell I guess. Kop
We've done 100s and had only a couple biggish problems but then we do a proper job which obviously commands a proper price. None of my work is in social housing. Retrofit is not for every property where gas is which is why its the most cost effective (not the most efficient) solutionAgreed mate normally being pushed by social housing schemes and often get it wrong soon as the depths of winter hit then it all falls down fitted a few not convinced it's the future. Kop
Reply to Watching the dash to electricity from renewables in the Plumbing Jobs | The Job-board area at PlumbersForums.net
