W
Winston
Why is it that 40mm 11/2 solvent weld pipe is actually o/d of 43mm and also different to pushfit and compression pipe?
Was installing a washing machine and dishwasher yesterday and I think the merchant has mistakenly given me the wrong part. As I have not been able to afford diamond core cutters I used a existing hole in the wall which was for 32mm pushfit.
So used 32mm solvent weld and went to get my 32/40 solvent weld adaptor but it didnt fit! It would fit the 32mm but not the 40mm. So in the end fitted 32mm then had to go and get a 40mm compression coupling and tighten up real tight then go to 40mm!
Am I missing something apart from a few brain cells?
