anyone with the above cookers need to contact the manufacturer immediately and stop using the cooker,8 people have already been killed the latest 2 in Cornwall this was in the sun paper 8/12/12
I don't know if I read the article wrongly but I got the impression that the grill produces CO when being used with the grill door closed.
I am just wondering why anyone would use the grill like that!
Read that in yesterday's paper, they've only managed to contact two thirds of the 21,000 people who bought one. Frightening to think there's still 7,000 of them out there with a problem.
we all know people wont read the mi,s but if you warn them it may kill them we can only hope common sense kicks in,at the end of the day if you fit/fitted any or come across any then kick it in for a mod to the grill door IMHO it should be a standard safety feature close the grill door and the grill wont work
My electric oven (aeg) tells in the instructions to close the door whilst using the grill. I never do that but maybe people have been confused by using previous ovens that told them to do it.
Shocking story. The manufacturers should be shamed for the way they have handled this. Its been going on for at least 4 years. To do with oven/grill door seals and poor design. Thats what you get with trying to make things cheaper to produce. You would think that the manfacturer would be more proactive in tracking down where all these cookers are.
Another one to note is the gloworm sxi/cxi range that came out with rubber/silicone burner seals. tech warnings went out fm gsr register, but I still come across these on new services where no one has upgraded the seal to graphite types! so they suck back their leaking pocs and soot up the hex, only problem being this one was serviced prior to the new owners buying the flat, and I found this as I couldnt get the fga readings down enough to pass so I had a look inside to see why!
do note the caring engineer's use of dust sheets on the work top:44:
just checked last years cp12 inspection and found ive got one of these beko cookers fitted in a rental.
will need to arrange a return visit early.
pleased i found this forum
Reply to warning> faulty beko,leisure,flavel cookers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, basic question, any insight much appreciated.
Looking to have an outdoor tap in my front porch fed from 15mm pex coming up from suspended floor. Pic 1 is inside porch, pex temporarily clipped to give an idea of pipe placement (ignore shoddy blockwork of booted cowboy builder!), Pic 2 is...
Morning to any Australians lurking around! Register its free, then message me, I'll sort your account out for you. We will need a moderator from each main country too.
I'll post this in the Australian forum now.
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT.
THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE.
THANKS
