Discuss Wanted Plumber North Norfolk - easy (?!) job in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
knocker
Hoepfully someone out there can help...
We've just moved into new house and the bath taps were leaking - easy to replace I thought so I sourced some nice ones and set about the job. I've removed the old taps and mounted the new ones on the bath but I can't get the flexible hoses (old and new ones) to seal properly and I haven't got any time in the next few days to sort it.
Hopefully someone can come out and fit some new hoses and give them a nice tight seal.
Cheers in advance.
Reply to Wanted Plumber North Norfolk - easy (?!) job in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A simple procedure has turned difficult. I am trying to disconnect a floor-mounted bidet so I can change the click clack waste. All is straightforward apart from disconnecting the two flexible hoses to the mixer tap. I had expected the two isolators to make this easy but was unable to turn the...
Help / advice please? I have attached pics I want to fit a new basin tap. The new tap came with flexible hose. Q1. Pic 1 - the fitting into the tap is recessed - how do I screw in the hose tight enough to 'fit' ? Q2. Pic 2 - shows the current hose fitted to the copper pipe and clearly the new...
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element required). This means that I have a 2.5 year old StainlessLITE Plus Horizontal unvented mains pressure 204L cylinder left over. We had it installed in Jan...
Peter M
Easy if you're a plumber I guess, but if you have no plumbing knowledge? Its a Bosch, nearly ten years old I think, its door won't shut, so it needs to be removed. They're a few videos that supposedly explain how to do it, but none for countertop dishwashers. I only saw one mention what you...
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm copper pipe. But this thing is not budging at all its like its welded or super glued on, I am using some water pliers on both points here but its not...
