Discuss W plan wiring using midposition valve in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Readingplumber
    Readingplumber Member
    Hi is it possible to wire up to work has a W plan using a mid position valve? If so any advise? Thanks
  2. king of pipes
    Found this online bud . cheers kop
  3. doitmyself
    doitmyself Well-Known Member
    If you connect the white and grey wires together they become the equivalent of the brown wire in a diverter valve. The orange is not used, so it should be "parked" in an unused terminal of the wiring centre.
    Why are you thinking of W Plan?
  4. Readingplumber
    Thanks just need it for a temp repair till major system renewal in summer.
Loading...
Similar Threads - plan wiring using Forum Date
Automatic bypass - s plan Gas Safe Registered Plumbers Only Jun 29, 2018
Nest on a splan +system Plumbers Arms May 10, 2018
