Discuss Vintage sink with small waste & lead washer seal... what to do? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jjkenya
First post... here goes:
We've acquired a second hand but lovely old sink which I've been tasked with plumbing in. The existing waste (plug/hole) is small - about 23mm ID. The lock nut on the bottom has a large lead "washer" or seal of some sort (I'm sure there's a plumbing name for it) which I think used to have some kind of sealant between it and the ceramic, but that's all cracked and dry now. The overflow is a weird ceramic cast overflow... photos will help explain.
The thread for fitting a trap to the sink waste has an OD of 28mm as far as I can tell. I just have no idea what to do next:
  1. Try remove the whole lot (and risk cracking the sink)?
  2. Leave it and try connect on to a plastic trap somehow?
  3. Remove it, clean it up and re-install the waste and thread (and then do (2))?
  4. How do you deal with that overflow?
I am pretty sure it would have been connected on to lead pipe back in the day... Not sure why that matters now. If anyone has any ideas, such as where to look online to find these old fittings, or perhaps what thread it's likely to be, or what size the waste is "officially", please share.
Thanks in advance.
Reply to Vintage sink with small waste & lead washer seal... what to do? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm installing my first Belfast/butler kitchen sink. It came with the waste and stainless steel drain. To my surprise the kit only has one washer in which the instructions clearly state that it should be placed underneath the sink. My question is, shouldn't there be a washer between the...
Hi guys first post. I am in the process of rejuvenating a double wash sink. It was needing the waste below looked at for a washing machine and dryer, as it had a sunken elbow and unbeknownst it was a mix of 1 1/4 and 1 1/2, including the sink wastes themselves. I bought new matching 1 1/2...
small hole in plastic waste pipe which is the better fix ? Hi there need some advice please, i have drilled a small hole in the plastic waste pipe which serves the sink & shower in the loft when doing some work in the toilet underneath on the ceiling i have cut away the plasterboard to reveal...
A while ago I replaced a leaky, corroded sink trap. That all appears to be fine, I can't find any leaks with it, and everything under the sink appears to be consistently dry. The problem I have is that there appears to be a leak where the waste pipe out from the bottle trap meets the wall...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone shower in the garage which has been removed. Unfortunately the pipes are only 1.5" on that side of the house since there's no bathroom and the house is...
