Discuss Vertical solar array in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Ermintrude
Any of you chappies any experience of these? Have about 15m2 very hot and sunny wall to fill?
We've got one to do in a couple of weeks, (only 10m2 tho) what specifically are the queries?
You may need to design sets of parallel and serial panels to meet the flow rate and temperature requirements, plus depends also where the pump station is what controls and 2 port valves may be needed plus usually at least one temperature sensor per parallel array, so controller will have to cope with multiple arrays. Plus what is it heating? DHW, Pool? THE RHI will have an affect on how it's plumbed if multiple uses..
No rhi it's for back of my house . You can't see the area I'm looking to use but it's ideal. Plant can be directly below. Will be feeding 300slme. And sneaky bit of ufh?
Not for a few months mrs 30weeks up the chuff and could do without the stress. Move, new business and new baby! Too much. Resting on laurels and bored.
Reply to Vertical solar array in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morning, Does anybody know what happens to a solar thermal flat panels (a pair on south facing slate roof) that have been unused for at least 12 months possibly year before also. System has been switched of due to loss of pressure. How will last years heat wave conditions have effected the panel...
Hello My solar thermal system appears to be leaking fluid (pics attached). Could anyone give me an indication of what the issue is likely to be and the potential cost to rectify? The system was installed in May 2021 and has a flat plate panel on the roof. It works very well generally and...
Hi all. Could someone help with a issue I have been having with my vertical radiator. I have one vertical radiator in my bungalow and it does not heat up unless the surrounding radiators are shut off. I have tried turning the surrounding radiators down but the have to be completely or very...
Just saying hello. I'm an electrical engineer restoring a house in Germany trying to work out a range of different things least of all German manuals and a solar system that I have very little idea about.
Hi, Solar thermal not so big these days but a couple of Q for anyone who still works in it. Background. I'm an Electrician not a plumber.. I've been maintaining my otherwise excellent solar thermal (Original install MCS by Others), for the last ~ 18 years, over which time I've needed to clean...
