Discuss Vaillant Specialist in NW London to remedy F78 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SomebodE
I've had this logged as a fault on the boiler on and off for a while.
Vaillant have claimed to fix it when attending site but the fault appears again after 2 months.
I'm about to have a house extension so it maybe worth waiting to attend, unless you think it's urgent to remedy!
Thank you for the opportunity.
If this job is for you please pm the op direct.
Reply to Vaillant Specialist in NW London to remedy F78 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be making things worse. I really need another expert's opinion, to put my mind at rest, or help me make the decision to stop using his services. I...
3K
I wonder if anyone has any thoughts? Combi Logic 30 Boiler - constant pressure loss - no obvious leaking. Few years ago we got an error code indicating pressure was below minimum. We resolved ourselves by using the manual and topping up per the guide. Sometime later, in some really cold...
1K
I moved into a flat over a month ago now and realized when trying to take a shower that there was little to no hot water - at this time I would turn the water on full out, it would stay cold for maybe 30 sec, it would then get noticeably warmer (lukewarm) and then run out again in maybe 15...
2K
M
Hi everyone. Really need some urgent advice on how to sort this and why this happened. Our normal plumber/gas engineer has been cleaning our heating system due to loud knocking noises the year before and after tests of water were done he used F3, then DS40 & F1 per the results, but nearing the...
1K
