Discuss URGENT- Help - Need to know the Output of this Fire (kw) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
It's not just based on the output.
Type of chimney, other appliances, room area. And mostly does it draw flue gasses.
All of this should be checked by a gas safe registered engineer. These tests will determine weather an air vent is neededPlease get one for this. It won't cost much, then you know you are safe.
Regards.
Reply to URGENT- Help - Need to know the Output of this Fire (kw) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
