Danv44444
Hi Guys,
I would like to ask your advice on an unvented cylinder hot water system please. I think me and another plumber have made a mistake when installing the cold supply from the main to the cylinder?
We have installed 22m Speed Fit pipe from the cold main directly to the multibock on the cylinder without teeing off anywhere else the run is about 12 meters.
There are 4 mixer showers and when you try and run 1 shower and 1 hot tap or cold tap simultaneously the shower temperature goes hot or cold and doesn't stay stable it runs luke warm or scalding hot.
I am thinking maybe we should have run the cold supply in 28mm and maybe had an accumulator, but surely it should work ok with one shower and one tap on.
Its an Albion Cylinder and we have checked and all the minimum flow rates have been exceeded.
To replace the cold supply would be a major job as all the carpets and flooring has been put down.
Id appreciate your help please guys, Dan
