- Messages
- 34,374
- Solutions
- 2
Cws tank to current vented cylinder....yes.
Why does the feed and expansion for the boiler need to be a mimimum 2m??
To have a high resistance so when hot water only is on it doesn’t pump over
Discuss Unvented cylinder size in the UK Plumbers Forums area at PlumbersForums.net
Don't like their price? Then just ask another firm to give you a quote.Its mad...things are going to crash soon...people simply arnt earning enough to pay the trades going rates
Thanks Shaun....think i need to rethink or fully understand what im needing ot what people are trying to inatall!....To have a high resistance so when hot water only is on it doesn’t pump over
and there lies the problem. Ring and leave messages and never get a response!Don't like their price? Then just ask another firm to give you a quote.
You are assuming the feed and vent are connected either side of the boiler? I'd have the feed and vent both on the suction side of the pump on a low head system, no pumping over and only consideration is enough head to prevent cavitation.To have a high resistance so when hot water only is on it doesn’t pump over
Bit beond me at present tbh...You are assuming the feed and vent are connected either side of the boiler? I'd have the feed and vent both on the suction side of the pump on a low head system, no pumping over and only consideration is enough head to prevent cavitation.
I have no F+E tankLike this. Both cold feed and vent on the flow pipe off the boiler.
You mentioned one in post #56I have no F+E tank
Removed nowYou mentioned one in post #56
"Raise f+e tank in loft."
Reply to Unvented cylinder size in the UK Plumbers Forums area at PlumbersForums.net
