Discuss Unvented cylinder question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SavageW
Replacing a leaking unvented,customer had two Ariston unventeds working in tandem eg one cold main split to two pressure reducing valves,shared dhw draw off & balanced cold,secondary returns,flow an return shared but only one Honeywell 2 port that then split to each primary flow of the cylinders coils. I’m querying wether it should have two Honeywell two ports one for each coil?
yes need two two ports as one could be upto temp and the other isnt
Reply to Unvented cylinder question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
