Discuss Underfloor & Gas Central Heating Engineer Req'd - HARROW in the Plumbing Jobs | The Job-board area at PlumbersForums.net
beekay22
Hi all
Im looking for a certified gas central heating and underfloor heating specialist in the Harrow (Middlesex) area.
I have an underfloor heating system that id like checked out - one of the rooms on the ground floor only ever seems to heat half the room.
Additionally as of today, my Ecotec Plus 637 boiler is very low on pressure. One of the pipes that is connected to the megaflow system is dripping (there is a manual valve connected to that pipe that when turned, discharges a lot of water).
I would also like someone to check out the wider upper-floor central heating system as when switched on, makes a lot of clunking noises in all of the radiators.
Thanks!
Biren (Beekay22)
Hi there mate. I'm sure some one from that area will get back to you.
Reply to Underfloor & Gas Central Heating Engineer Req'd - HARROW in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my house, in place of the garage, most would give me a suggestion to put in a) an extension to the existing boiler rad circuit & electric water heaters...
eco-heating options
E
N
Hi! We're looking for a consult for our 1905 built (renovated in 2010) victorian house for the future of our heating system. The house is 2 floors and runs 2 different systems and hot water. On the ground floor we have water based underfloor heating with a mix of tile and wood floors with...
Hi, I'm after some advice on converting my current CH system to Wiser smart system. In particular, looking for advice on whether I can use the Wiser Hub without using Wiser's specialist Underfloor heating controller. Current set-up • System boiler (Vaillant ecoFIT pure 630) with unvented hot...
1K
I have a 320 sqft double storey house with 6 bedrooms. The house is serviced by two heat only boilers (non condensing); a 120k btu (35kw) and a 70k btu (20kw). Both Boilers are installed at ground floor (120k at front and 70k at the back). Front boiler serving front downstairs and upstairs rooms...
1K
